I've used the Mermaid and it works quite well. However, I'd point out that the stock raw water heat exchanger
pump, the Teel, is a lousy piece of kit. You're much better off going with one of the upgraded
pumps, but not buying it from Mermaid, since they charge a premium for it.
The Teel
pump:
You're much better off with a higher spec, more durable March
pump, like this one:
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
