SailNet Community - View Single Post - Feathering Prop vs. Fixed Blade Prop
post #67 of Old 02-10-2011
Jeff_H
Moderator
Jeff_H's Avatar
I cannot imagine why PS thinks that the transmission needs to be left out of gear. Its not like a car transmission with syncros which do not like to be shifted with the engine off. Actually race boats do this all the time. Typically the shaft is marked when the boat is out of the water so that you can locate the blade up position (mark both blades). When you want to center the blade, you put the transmission in neutral and then rotate the shaft with your hand (in the engine compartment) until the marks show teh blade is in the up position. Then you put the transmission in reverse. That locks the shaft on most marine transmissions.
Jeff_H is online now
