SailNet Community - View Single Post - reefing lines
Thread: reefing lines
post #20 of Old 02-12-2011
svHyLyte
Old as Dirt!
svHyLyte's Avatar
Originally Posted by catamount View Post
The Problem with svHyLyte's suggestion is that you need a forward pull on the tack line, otherwise all the pressure of the sail will come on the first luff slide above the reef.
Here's one possible solution -- add a small block on a strop to the top of the boom to help re-direct the reef line so as to avoid chafing against the edges of the sheave box:
This isn't a bad suggestion.
However, the simplest solution is to remove the bull'seye block from the mast.
Alternately, one could simply use a double sheave exit block on the boom such as the Harken H089:
svHyLyte is offline
