SailNet Community - View Single Post - Soft soft soft
Thread: Soft soft soft
post #6 of Old 02-20-2011
zz4gta
I don't discuss my member
zz4gta's Avatar
Originally Posted by paulk View Post
Tapering would be the best option if we were in the market for new sheets. Our spinnaker's 1000 square feet. 5/16" would tear off fingers a good puff, so our sheets are at least 5/8".
And you crew doesn't use gloves, winches or ratcheting blocks to help with the load? 5/8" is ridiculous for a boat that uses 1000sq ft chute. The load is less than 1,000 lbs in 15 kts apparent. In light air you won't be using a winch, and the heavy sheets hurt performance. When the wind picks up, you're using a winch anyway, what's one more wrap?
Check out the big boats, they don't have anything that's over 1/2". They just use higher tech lines.
Merit 25 # 764 "Audrey"
zz4gta is offline
