SailNet Community - View Single Post - Topping Lift and Sail Shape
post #7 of Old 02-23-2011
sailingdog
In very light conditions, a flat main won't generate any lift...and you won't move... also, not supporting the boom will close the leech of the sail, as Faster pointed out, which was my reasoning for supporting the boom with the topping lift...to allow the sail to have a fuller shape to help generate lift and to keep the leech open. Yes, flat sails help with attached flow, but you have to balance keeping the flow attached with sail shape to maximize lift. A flat sail generates almost no lift.
Originally Posted by Skipper995 View Post
I have to disagree with sailingdog on one issue however. In very very light conditions the main needs to be made as flat as possible to try and squeeze as much power out of the breeze as possible. In these conditions air flow has a very hard time staying attached to the sail. Detached air flow means loss of efficiency and power. A flat sail allows the breeze to maintain nearly complete flow attachment for best sailing performance.
sailingdog is offline
