SailNet Community - View Single Post - sail cover
Thread: sail cover
post #3 of Old 02-26-2011
sailingdog
Well, you might also consider that the real purpose of a sail cover is to protect the sail from UV. Tyvek may not block all the uv that a heavier sail cover made of traditional materials would. This means your sails, which are a bit of an expense to replace, may be getting more UV damage than they should. Also, you have to consider the time and effort that goes into making the cheap tyvek sailcover could easily go into making a much more durable, more protective sunbrella sailcover just as easily.
BTW, Tyvek, at least heavy duty Tyvek that would be suitable for your sailcover isn't that cheap. Going the cheap route usually ends up being far more expensive than doing it properly.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
sailingdog is offline
