Old 02-26-2011
Faster Faster is online now
Here are some examples of hull deck joints. This should help you to decide what would work for you if you can determine what you've got.
"C" is a 'shoebox' style, "D" is an outturned flange style.. etc. However your boat may be different from any of these.... The Irwin diagram shows the same aluminum rail you're thinking of... (but think bolts/washers/nuts instead of those little screws) I suspect this is similar to your hull/deck joint arrangement. I've found several A30 blogs touching on the subject..
