Depends on the strength of the winds you normally sail in. If you're in an area with stronger winds normally, then a heavier weight sail is going to do much better than a lighter weight sail, since it is less likely to get blown out and distorted by the stronger winds. As I don't sail in your area, I can't say what your typical winds are like...
