SailNet Community - View Single Post - Weird 'severe' vibration
post #4 of Old 02-28-2011
sailingdog
Yes, the dripping water is to cool and lubricate the shaft where the packing gland is. Have you dove or had someone dive to inspect the prop, shaft and strut? If not, you should. Also, have you tried loosening the knuckle again? If not, you should.
If the prop shaft, prop and strut are clear and there is no growth on the prop blades, and you loosen the knuckle and the vibration returns, then I'd recommend following Rich_H's instructions.
sailingdog is offline
