SailNet Community - View Single Post - Shaft seal leak
Thread: Shaft seal leak
post #6 of Old 02-28-2011
MJBrown
October Moon B43
If you have a Volvo shaft seal there are no adjustments. The only maintenance is relubing the lips of the rubber bellows around the prop shaft. I assume when they replaced the shaft they reused the Volvo shaft seal. If your unit has a hose attached to a nipple check it for a leak. Look but don;t touch!!! Earlier models were metal and need to be replaced every few years. WARNING do not mess with it unless you can be sure to be hauled on a moments notice. The typical failure mode is the nipple breaking off flush with the shaft seal. Once that happens there is no way to stop the water ingress and unless you're hauled ASAP you will sink.
MJBrown is offline
