SailNet Community - View Single Post - Newbie: Centerboard / Swing keel distinction
post #4 of Old 02-28-2011
sailingdog
I'd first point out that a centerboard is usually an unballasted foil which is designed to allow the boat to resist leeway and point higher, where a swing keel is ballasted and designed to help the boat point higher but also to help keep it upright.
While you are learning, leave the swing keel down all the way. After you get some experience, you can start experimenting with raising it. Raising a swing keel or centerboard will also affect the boat's Center Of Lateral Resistance, and can change the amount of weather/lee helm the boat experiences. Retracting it completely can reduce wetted surface area and drag.
sailingdog is offline
