Thread: Fuel line??
Old 03-03-2011
SlowButSteady's Avatar
SlowButSteady SlowButSteady is offline
Senior Slacker
SlowButSteady is on a distinguished road
As long as the diameter of the supply line is sufficient to get enough fuel to the engine at full throttle, then it should be fine. If you haven't had any trouble with the engine acting like it was fuel starved, I wouldn't worry about it. However, if the fuel hose(s) are more than a few years old, I would replace them with some of the new ultra-low permeability hose. The standards have been updated recently, and the new stuff is much better.
The return line should be the same diameter as the supply line. The vent line for the tank is usually a bit larger.
LET'S GET SERIOUS ABOUT GUN CONTROL, NOW!
