SailNet Community - View Single Post - Pulling transponder cables
post #6 of Old 03-04-2011
sailingdog
Yes, but this generally doesn't work for transducer wires, which are usually affixed to the transducer at one end, and must come into the wiring conduit via the transducer end. Unless you're cutting the wire at the old transducer, it can't be used to pull wire in the proper direction—transducer to instrument display—so you generally need a messenger line. I don't recommend cutting the transducer wires, even on the old transducer, because they might still be useful.
It may be possible to use the original wire as a messenger to pull the new through - though creating a compact temporary splice can be a challenge. Also any fittings/cable ends can complicate this procedure.
sailingdog is offline
