SailNet Community - View Single Post - Cored deck soft spot repair
post #21 of Old 03-05-2011
captflood
Greetings all, if you use a ink refill syringe small holes on 45 degree angles pump in unthickened epoxy, this will bond together and gives good results. If using from undernithe small hole lets the wet area drain and can be blocked with a match or twig. when you have drilled your holes put some tape over the same selotape or insulation tape, pierce with needle of seryinge when epoxy ouses out wipe and place heavy weight over to keep constant pressure over area when cured remove weights and tape this should leave a nice neat neary, undetecable repair. Weather is a joke from God we just make use of it so enjoy what he gives. GO SAFE
captflood is offline
