SailNet Community - View Single Post - galvanize shrouds/stays
post #2 of Old 03-13-2011
Boasun
Boasun's Avatar
Originally Posted by PeterSailer View Post
What do you guys think about a blue water sailboat rigged with galvanized shrouds and stays? My Idea is to replace old SS stays/shrouds with galvanized wirer that have the equivalent breaking strength of a oversize SS wirer for a given yacht.
example: Replace 1/4 SS wirer (breaking strength 8200 lbs) with 5/16 7x7 galvanized plow steel wire (breaking strength 10100 lbs). 5/16 galvanized wirer has the same breaking strength as 9/32 SS wirer which is one size bigger than 1/4.
I would do the same thing with the turn buckle.
So it would be cheaper and stronger that way than replacing your old standing rigging with new SS wirer.
Other than looks, windage and weight anybody see any draw back?
Those are the draw backs; windage, weight and galvic action. And to reduce the galvic action they heavily tarred the crap out of those stays & shrouds.
But if you are stepping back, why not go back a couple of centuries and use fiber stays & shrouds. Instead of tarred Manila, use spectra 800 or 900. They are now manufacturing shrouds now from spectra. you save humongus weight aloft and the shrouds will just as strong as SS rigging, if not stronger. You should investigate the avantages and disavantages in the costs, life expectency of the modern shrouds using spectra.
This is food for thought.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Boasun is offline
