SailNet Community - View Single Post - Recommended Solar Panel.....
post #23 of Old 03-14-2011
SlowButSteady
Senior Slacker
SlowButSteady's Avatar
Also remember that if you use your engine a couple of times each day you go sailing (in and out of the marina, and/or to anchor) you should probably run it at least 20 or 30 minutes or so each time you start it to get it up to full operating temp. In that case, once you've replaced the juice you used starting the engine, you'll be charging your batteries at a fairly high rate (probably something like 20-25 amps, at least. In other words, much of your electrical requirements will probably be met by the normal use of your engine.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
