SailNet Community - View Single Post - Outboard motor shop scam?
post #42 of Old 03-18-2011
pvanv1
Hinterhoeller HR28
pvanv1's Avatar
"They recommend I run it in a bucket of water after using it to keep it from getting corroded again. Problem is, it is not very easy to remove from my boat while its in the marina. I guess I will have to figure it all out because I don't want this to ever happen again."
If you have garden hose water at the slip, consider using the Tohatsu flushing adapter Part # 336600070M, $7.07. To use it, you unscrew a plug on the motor near the LU upper lube plug, screw in the adapter, connect to the garden hose, and let 'er rip for a few minutes. Now, if it's unreasonable to get to that section of the motor while at the slip, that's not much of an option.
Paul Van Voorhees
Certified Tohatsu TLDI Technician
Mgr, Obersheimer Sails
Buffalo, NY USA
pvanv1 is offline
