SailNet Community - View Single Post - Sabre 38 core moisture
post #1 of Old 03-21-2011 Thread Starter
Andrewbradley
Hi All,
Just had a 1989 Sabre 38 mkll surveyed which has a fully cored hull and deck.
Surveyor has indicated all moisture readings around hull are 11% and should be considered dry...Except in a couple of places around thru'hulls below the waterline where moisture redings are 18%. Vessel has been on hard since October.
Another couple of similar areas are found on the coachroof around organiser and on the fordeck in a line running between the two forward cleats.
Again, no delamination just localised elevated moisture readings.
The surveyor is indicating that this is normal for a vessel of this age and nothing to be alarmed at and the hull issues can be cured by removing thru hull fittings and scraping core back, filling with epoxy then replacing fittings.
All was good but now am getting nervous of cored hulls. I know Sabre are a quality builder, the reason I chose in the first place, but would appreciate any views in particular from anyone who has had similar issues.
Thanks, Andrew.
Andrewbradley is offline
