SailNet Community - View Single Post - Removing lag screws corroded on strainer thruhull
post #1 of Old 03-28-2011 Thread Starter
After removing my strainer thruhull to rebed, found that instead of using 4 bolts and nuts to secure the strainer through the hull, lag screws were used. Now I have 4 screws(heads are corroded off) going completely through my hull. The tips of the screws are just breaking through the inside of the hull. Any easy way to remove these. Also could I use epoxy to fill the holes afterwards, or would i have to reglass.
Goblinfog is offline
