SailNet Community - View Single Post - Auto or Manual Bligle Pump for my little 17'er?
post #4 of Old 03-29-2011
celenoglu
celenoglu's Avatar
A small bilge pump is needed for water rarely collecting in the boat. One should always think about the worst. In case of holing the boat you will need a high capacity pump. Install a small auto pump and a manual high capacity pump. Automatic bilge pumps do not use electricity when not running. If ytou want them to run less frequent you can install the auto switch a little bit higher in the bilge. In this case the pump will run later and discard most of the water and will not run for pumping air.
celenoglu is online now
