SailNet Community - View Single Post - Prop for 8 HP Tohatsu and 26' sailboat
post #7 of Old 03-29-2011
tommays
tommays's Avatar
You only need to use the tack to test your current setup to see if can be inproved as going to to small a prop would make it worse and give you the abilty to run the motor at to MUCH RPM
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
