SailNet Community - View Single Post - VHF antenna install on Quickstep 24
post #2 of Old 03-30-2011
sawingknots
i would just drill another hole a couple of inches from the anchor wire[just big enough for the vhf cable] i would buy the bigger vhf cable and seal it with a good sealent[apply some to the cable before pulling the last couple of inches through,if your new hole is a slightly tight fit i doubt you will have a leakage problem,a stern mounted antenna on a sailboat doesn't work well at all
sawingknots is offline
