Hello
Spring is around the corner and I am looking for a 40 or 41 footer
Just a coastal cruiser but needs to be able to trail with a Durango
Looking at Beneteau / Catalina/ Hunter but all come with long keel
Unfortunately, the boats that you are looking at will not work from a towing perspective. Here are a few things that you need to consider when towing:
Weight- The maximum towing capacity for a Durango is 7,400lbs for a 2wd one with only a driver. Realistically, it will probably be 6000lbs of which 2000 lbs goes to the trailer. A 4,000 lb boat is pretty small, I don't even know of any 30'ers that would meet this requirement. Even if you upgrade to a one ton dually you are unlikely to find something in the 40' range. You would probably need a medium duty truck and a CDL.
Height: The total height will be from the bottom of the keel to the highest point on the cabin/stanchions plus at least a foot for the trailer. Being much over 12' is pretty limiting.
Width: It depends on the road but much over 9' gets problematic. You can get wide load permits but they are expensive and inconvenient.
There are 2 ways to deal with this. First, you can look at a boat that is trailerable by a Durango/whatever vehicle you are willing to buy. The other option is to buy a boat that you can't tow and pay a professional hauler to move for you. You still need to make sure that it isn't too big for them.
That citation displaces almost 16k pounds, the trailer needed would be at least 8000 lbs which means a Gross vehicle weight of at least 24000 lbs.
A vehicle capable of pulling that is at least a f450. The max weight rating for towing on your durango is 8 to 10 k depending on your engine.
I tow my 27 foot bristol which including cradle is about 7200 lbs and the flatbed was about 7000 lbs and i was within a couple thousand of my maximum tow capacity of my 2500.
Also the beam is not legal as well.
If you are looking for a trailerable with the durango, you are really only going to be able to look at the 20 - 25 foot range.
So now I understand that the boat is too heavy for a trailer
Should I then carry the Durango on Deck ?
After all my Irwin citation 40 is a centerboard and a little weight in the center should help!
Just make sure you have some nice salty teak brackets to hold it secure amidships, and keep the rubber off your decks - it'll be a pain to clean otherwise. Say - in addition to a little more weight, it'll also give you some more windage...you'll probably go faster 'downhill"?
I hear Hunter is coming out with a 45-I......an inflatable blue water cruiser, that will easily fold down into a pop-up camper sized trailerable package. The Mast is telescoping, and will collapse to a 12 foot pole.
Seems the original poster was fooling, but isn't the 32' Seaward trailerable by a one-ton pickup? The same F350 crew cab dually diesels that are launching 15 foot Bayliners, driven by guys looking at me like I'm crazy for launching a 17 foot boat with a six-cylinder station wagon.
The best trailerable boat that I've seen is one that I used to own. It was a Harstad 31 Motorsailer.
She was a 31 foot, center cockpit, ketch-rigged sailboat with an eight-foot beam to keep her legal on the roadways. She weighed in at 8000 pounds and originally came with a trailer.
Although Crealock designed her, I imagine that he was trying to pack too many features into this small a package. She had a lot of pluses, but she also had her down sides.
She was not a good sailing boat unless you ran the diesel most of the time. She was a bit narrow, but had 6' 7" of headroom throughout. Although she was center-cockpit, the aft cabin was separated by the engine room. It was roomy, with two bunks and storage, but the separation was a problem.
Assuming it is NOT an April fools post,,,,,,, then again, with thefrencha only having 5 posts since 2003.....one never knows, then again, the poster could be an unknown sock puppet.......but lets get back to being serious instead of not........
I believe Bob Perry designed a "Container boat" a few years back, I believe that boat would qualify, as IIRC it was 8-8;4" so legal from with width stand point. Weight wise, do not remember, could be a bit heavy for a light duty SUV. a 25 series SUV or other 8 lug rig with a larger motor, should not be an issue........bridge height wise with the keel on could also be a potential issue.........
There certainly is a boat that meets your requirements, the Cape Bay Fast 40 I've seen it on a trailer. It is very light and only 8' wide. The name is Lawndart and I think it's the most appropriately named boat I've ever seen. From what I've read it weighs 4,000 lbs.
Check out: Transpac 03 Boat Bios FAST 40 - Sailing Anarchy Forums
Related Threads
1.7M posts
173.8K members
Since 1990
