SailNet Community - View Single Post - Diesel fuel lines -Universal 3cyl diesel
post #1 of Old 04-03-2011 Thread Starter
argofred
All: Just having replaced all filters for the season I found that the fuel line from the pump to the secondary (spin on ) filter is in need of replacement. They all probably should be replaced actually. One end is a brass fitting with the hose crimped on fitting while the others have brass fittings (fine pipe threading?) on both ends. If I remeber the lines can be made by the right shop. Nobody seems to stock generic equivalents so will a good marine engine shop be able to make them? Thanks!
argofred is offline
