SailNet Community - View Single Post - More Newport Questions- side windows
post #2 of Old 04-04-2011
Faster
There are companies that can custom make any shape/size portlight frame and lens you might want.. That would be the best solution but not necessarily the most cost effective.
Unlikely you'll find a source of identical replacements anywhere else, though.
You could change to screw/bolt/glue on acrylic ports attached to the outside of the cabinsides, the sealant Dow Corning 795 has proven effective with this type or installation. It would require you to make a trim ring for the inside to look nice, but it also allows you to update the look a bit as you could design a more contemporary portlight shape.
Faster is offline
