SailNet Community - View Single Post - Yanmar 2qm15 fuel problem
post #2 of Old 04-05-2011
haffiman37
Providing your injectors performs as to specs when it comes to opening pressure, no 'drips' and spray pattern, I would do a compression test.
The pump clearly gives fuel needed and a bit more, engine does not burn it!
That pump can not start giving more than it is set to deliver, however it might give it later.
Suggestion:
1: Do an injection timing check.
2;Do a compression check on both cold and hot engine.
haffiman37 is offline
