SailNet Community - View Single Post - Yanmar 2qm15 fuel problem
post #5 of Old 04-06-2011
jrd22
Courtney the Dancer
jrd22's Avatar
Will it not start at all without starting fluid? Interesting that it ran better, but you really didn't change anything, right? The injectors were not rebuilt? There could be a lot of diesel in the muffler that is still puking out, but that should clear up fairly quickly.
Unless you have access to a diesel compression gauge and the correct fittings you won't be able to do a compression check yourself. Some shops prefer to do a bleed down test using compressed air and measuring how long the cylinders will hold a certain PSI.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
