SailNet Community - View Single Post - VHF Suddenly needs to warm up??
post #2 of Old 04-08-2011
Gladrags1
Sailor
Gladrags1's Avatar
Sounds like you may have a loose connection inside the VHF or, more likely; corrosion in the wires making the connection to your wiring harness. Try disconnecting the radio, cleaning the connections with sandpaper and reconnecting the radio. If that doesn't work, its probably internal and you'll probably have to replace the unit.
Tod
Gladrags1 is offline
