Not sure about the PCS / PSC issue.
The boat manufacturer must display two identical hull identification numbers, no less than one-fourth of an inch high, on each boat hull. The primary HIN must be permanently affixed (so that it can be seen from outside the boat) to the starboard side of the transom within two inches of the top of the transom, gunwale, or hull/deck joint, whichever is lowest.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
