SailNet Community - View Single Post - So we found a boat we like..... Now what?
post #8 of Old 04-14-2011
Tim R.
Tim R.'s Avatar
1) Could be from the mast if it is keel stepped. Many boats have water in the bilge and should not automatically be a deal breaker.
2) Big job to make it look right again.
3) What you can see inside that is damaged is likely just the tip of the iceberg. I have done this job and it looked minimal until I cut into the plywood and found a large portion rotted while the outer veneer still looked good. Veneers are usually better species than the substrate which tends to hide the real problem underneath.
4) Big $$$
5) If 29 years old then it has lived 3 lifetimes. Replace before you sail. If not then get a qualified rigger to do dye testing on it to ensure it is safe.
6) New bottom job is a plus if done properly. Look for receipts for this.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
