Pictures compression post base
I am considering purchasing an Islander 30 MkII as well. I have pictures of part of the substructure under the cabin sole under the compression post. It is not pretty. Would you like me to send them to you? This boat has about 3/8" compression of the cabin sole and substructure, and there is a plywood shim installed. Were you able to solve your problem and how did you accomplish it. I would like to determine whether this is worth fixing and if I should continue with the purchase of the boat.
