SailNet Community - View Single Post - Diesel fuel lines -Universal 3cyl diesel
post #3 of Old 04-14-2011
SeaFever2000
I second that. When I re-powered to a Universal M25 last year I put all new fuel lines and engine control wiring. I used marine grade (USSG approved) rubber fuel lines with brass fittings. Got the fuel lines from local marine store and all brass fittings from Ace Hardware. Make sure you get all-stainless-steel hose clamps and not the ones with a steel screw. You will be done. The rubber fuel lines are easy to get, route and install.
SeaFever2000 is offline
