SailNet Community - View Single Post - Stern Anchoring Question
post #6 of Old 04-16-2011
JohnRPollard
Moderator
JohnRPollard's Avatar
Originally Posted by Mandofish View Post
... Why is this technique never used or talked about? Seems a lot easier, especially for singlehanding, rather than dealing with tackle at the bow.
I've used a variation quite often. It's definitely not revolutionary.
I don't think i would have the tearing thru hands problem if i cleat off the rode, then walk the bitter end to the bow, cleat, then release stern cleat right?
I Appreciate your directions, its exactly what i read everywhere. Any other reasons my technique wouldn't work?
The change I would suggest that you make to your plan is to also cleat the anchor rode at the bow before you deploy the anchor from the stern. That way when you uncleat at the stern, you can essentially just release the rode and let the boat spin. Probably best to walk it up a short ways to make certain the boat spins in the right direction.
That said, you need to be very careful when deploying an anchor from the cockpit. You'll need beefy hardware and you'll need to be very careful about making sure no one gets tangled in the anchor rode. If you have much chain on the rode, it can be a bear hauling it all back -- led outboard -- to the cockpit and making sure it doesn't do damage to crew or boat. Not always a simple operation when you are short handed.
We have a stern anchor, stern rode locker, and a stern anchor roller, which makes it comparatively easy.
JohnRPollard is offline
