SailNet Community - View Single Post - Islander 28 Backstay Adjuster Preferences
post #3 of Old 04-19-2011
Faster
On a rig with in-line spreaders it's not advisable to but a multi part purchase directly into the backstay unless you also have a wire strop as a safety (ie set at the minimum tension setting). With swept spreaders it's unlikely the mast will fall down if the tackle fails or is accidentally let run free, but with inline spreaders the backstay is the only thing pulling back on the stick. This is probably why the split backstays are popular for adjustment.
I think hydraulics or mechanical 'screw' type adjusters are otherwise the way to go.
Faster is online now
