SailNet Community - View Single Post - Tacktick Mounting Opinions/Questions
post #1 of Old 04-19-2011 Thread Starter
Tanley
Tanley's Avatar
Replacing the 2 old Datamarine Speed and Depth w/ T108 Wind and Dual Display Speed/Depth. I like what Sailingdog did by mounting his in a single opening port, but I'd like to consider using the existing cutouts for the new instruments w/o cutting or drilling any new holes.
The 2 TT displays are removable from their mounts so I was considering mounting a deck plate into each of the 2 existing 4" holes and simply securing the TT mounts to those plates. What I'd rather not do, is drill additional wholes around the circumference of the trim ring on the deck plate.
Questions:
  1. Will I be able to get the old DM instruments off cleanly?
  2. Has anyone seen or had experience with compression deck plates as opposed to through bolt?
  3. Will the old speed transducer's thru-hull come off the hull cleanly enough to re-use the hole or is this a bad idea?
I found these compression deckplates, although they're of the wrong diameter, it's the general idea:
Water tight Deckplates by Armstrong Nautical Products
Here's what I'm imagining:
Current setup
Bracket
Tanley is offline
