SailNet Community - View Single Post - Creealock 37 rudder
post #6 of Old 04-27-2011
Lansdowne
Wing n' Wing
easy out
If you go slow, and are handy with a drill, you can buy a "easy out" at the hardware store. You size it to the bolt you are removing.
Drill the center of the sheared bolt, insert the "easy out" spray release on the bolt, have lunch, come back and very gently crank out the sheared bolt by turning on the easy out.
Two new screws or bolts and your jake...
Lansdowne is offline
