SailNet Community - View Single Post - Got caught in a Squall today
post #6 of Old 04-29-2011 Thread Starter
Aac
Originally Posted by CharlieCobra
The amount of turbulence at 40 knots coming around the furled jib is enough to break the air off the surface of the sail.
I like that explanation. I’ve read a number of threads on reefed furled headsails and didn’t expect to experience a con I was unaware of. A deep reef on a furled headsail looks horrible and I guess they behave the way the look. A stay sail like imagine2frolic suggests is something I need to look into. The mast on my boat is way forward, unlike a cutter rig, with J=4.32m and E=5.9m; I think that I should still be able to fit a stay with a J of maybe 3m –must talk to a rigger.
Originally Posted by rockDAWG
I wonder if you can fall off a bit on your heading will eliminate the shudders
This may have helped but the feeling I had at the time was that I had too much sail up to fall off; my guesstimate was even with a second reef on the main and sheeted out there would have been way too much heel. Were it not for heaving to I would have then attempted to drop the main completely.
Probably also worth mentioning that I have spent a total of 193 days on the bay sailing and often 20 knots plus; today was different due in part to the behaviour of the rig.
What I'm trying to get at is how would a 100% jib that is not furled behave; my thought is that it would have been fine. I’ve read a lot on overlapping versus non-overlapping headsails and I am still lost as to what way to go. The current boat moves well to windward with a 135% overlapping head sail in anything under 15 knots of wind; above that though I find that the 135% is too much and the furler is used for reefing – a PITA.
Aac is offline
