SailNet Community - View Single Post - Advice, article or procedure on painting bootstripe?
post #5 of Old 05-03-2011 Thread Starter
needabiggerboat
Originally Posted by JimsCAL View Post
Don't think the order is particularly important, but don't see how you can do both the blue and white simultaneously. You'll need to let one dry before you and tape the second. As for the paint, a decent oil-based enamel is OK. Better is a single part polyurethane like Pettit Easypoxy, and best would be a two part polyurethane like Awlgrip. I would go with the single part polyurethane.
I am assuming the current bootstripe is painted and needs renewal. On many boats (like mine) the bootstrip is colored gelcoat and just needs polishing and waxing each spring.
Thanks! Sanded last night and if the weather holds am going to paint this evening. Going to use the Pettit you recommended. Do you know if one quart will cover what I compute to be about 30 sq. ft.?
needabiggerboat is offline
