SailNet Community - View Single Post - can sailing guarantee my safety?
post #15 of Old 05-04-2011
chris_gee
To some extent it is possible to largely avoid storms depending on where you go. However on some routes eg Fiji to NZ which takes say 9 days one storm is most likely. It is also likely but not certain that at some point on passage you will go through a gale. More so if you take chances in your planning. You are unlikely with normal caution to encounter a hurricane.
With experience and the knowledge and equipment to handle bad weather you will be uncomfortable, and scared but will most likely survive. Some anxiety is normal but with experience you build up your tolerance level.
chris_gee is offline
