post #950 of Old 05-05-2011
myocean
The Baba has a big load capacity. It can carry 75 gallons of fuel and 100 of water. Well on the Azuree 33 the fuel tank dimension is not very important because it is a very good sailing boat that can sail with very weak winds, but the water is indispensable for having the autonomy for staying some days atanchor. The Azuree only has a water tankage of 160L and that's really not enough for living aboard. the Elan 350 has and identical problem. I think that this will be the biggest problem, not the interior space.
I think for living aboard a good solution for this issue which is actually a weight-issue is a watermaker. Use the water tank as buffer and for safety but use the watermaker for the continuous demand. However the energy for this needs to come from somewhere, e.g. from the watt-and-sea generator. So its going to be expensive...
myocean is offline
