SailNet Community - View Single Post - Cooper 416
Thread: Cooper 416
post #8 of Old 05-08-2011
Hi Doug,
Thanks for reply. Having owned a 416 since 89 you must be very happy with her?
I would appreciate your feedback on the following if that is possible.
I like the pilothouse look but am not sure if the windows are to big. As I will be doing a lot of bluewater sailing in the south pacific & southern areas of Australia I will encounter big seas. Do you think the windows are up to it?
Where do you keep your propane tanks?
I was under the impression that Cooper sold the molds to Bayliner in 81 after a fire at the factory & from that date the Cooper 416 was made with the name US42. Is this correct or is yours a genuine Cooper 416 which goes against the reviews I have read?
Yes, some have single & others twin spreaders. Which is the same with the bbackstay. Does your 416 have a single or twin backstay?
Others have said that the tanks can split & then big problems to fix them. Have you encountered this problem & if so what was your problem & how did you fix it?
As I will be doing extended cruising, do you think your water & fuel tankage is surficient? I am thinking that more water would be good. I noticed uyou have extra water in the v-berth. Is there other areas where another water tank could be placed?
The other choice is to install a water maker. Is there room for this to be done?
The photos of your 416 show her a a very lovely yacht, congrats. I do not see any solar panels or wind genny. What & how many batteries do you have & what do you use for charging them up?
You mentioned growth on the hull. Is this due to the beam?
I am 6' 3'' tallso am wondering what sort of headroom do you have in the fwd cabin, head, saloon, galley area & the aft cabin?
Is the chain locker very big? How much chain/warp do you carry there?
Sure to have other questions but wont bother you with them all at once.
Look forward to your reply.
SVEtosha is offline
