SailNet Community - View Single Post - Painting an aluminum spar
post #6 of Old 05-08-2011
tommays
tommays's Avatar
I sprayed it But I have the stuff and know how to drive it and had a room with a explosion proof fume hood
I am roll & tipping the cal 29 hull As it's just To big to spray safely in my driveway Even with the tent
I went with perfection because of the yellow Vin-wash as the Awlgrip version of it requires putting on some otherstuff and then washing it down with a hose which was out of the question in the indoor place I was painting in
I am using Awlgrip on the Cal 29 hull due It being made in the color we want
I striped it really careful and then did a light sanding with my random orbit sander to skuff it up good
The Perfection and Awlgrip are and equal PITA to apply correctly
Both the paints are and equal PITA to put on right
There is no sanding between the yellow and the primer but the primer has to be wet sanded a bit as will the coats of the paint after they dry 24 hours
It will take two or three coats of color
When you here prices of 100 dollars a foot to paint a mast there NOT over charging as it's a lot of hours to do a good job
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
The Following User Says Thank You to tommays For This Useful Post:
Rhapsody-NS27 (07-08-2016)
