SailNet Community - View Single Post - Standing rigging won't
post #3 of Old 05-10-2011
Tim R.
Tim R.'s Avatar
I think you are confusing different terms. The turnbuckle is the center part that you turn to adjust the rig. The threaded part that fits into the top of the turnbuckle is a swage fitting. You do not have the proper press to swage a new fitting. Nor should you use the hand crimps found at the local West Marine. This type of swage fitting actually squeezes the fitting around the wire at a very high pressure. So high that it fuses the wire to the fitting. No way to take apart and repair. So using the same wire would require you to cut the wire where it enters the fitting. If you have broken strands at one location, the rest is soon to also fail.
Just pay the $500 and replace everything. Your lack of rigging knowledge is a sure sign that you should not be trying to band-aid a solution. Stay safe and have it done right. Your family and friends will thank you.
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
