SailNet Community - View Single Post - Yanmar instrument panel source -used?
post #4 of Old 05-10-2011
casey1999
casey1999's Avatar
Sounds good.
My panel is mounted in the cabin so not so much corrosion problem. My wiring harness (and connections) are not in good shape either, but I know what to wiggle to get it to work (repair is on the list). It would be good to use some anti-corrosion spray on everything (make sure it will not damage rubber) including in the wiring harness plugs and splice plugs.
casey1999 is offline
