SailNet Community - View Single Post - Columbia 36 Shower
post #5 of Old 05-12-2011
just find any tupperware that will fit into the bilge, buy a cheap 500gph pump and a separate float to control it and mount both in the tupperware and have the shower sump discharge in it, the float will automatically pump it out. you dont want to let the shower discharge in the bilge, the soap, oils, hair, scum, all in time will make a stinky mess... you can always place the pump assembly in the next bilge area aft and simply drill a hole for the shower hose to run thru if the bilge next to the head is too small.
make sure the "tupperware" is deep enough so water doesnt spill when healing. another advantage of placing the pumping station a bit aft is that you can now let the ice box drain into it as well.
gon2sea is offline
