SailNet Community - View Single Post - Beneteau 311 vs Tartan 31
post #3 of Old 05-13-2011
On a 30 year old boat you have to make a lot of questions, for example: When was the rigging changed? (some say that should be changed every 10 years, some say more, but certainly a 30 year's old rigging is not fit anymore). The mast is the original? If so you have to look very carefully. Aluminum tend to turn brittle with time and to corrode on the links. The boat engine?....the freezer engine?...the pumps?, all rubber parts... last time the boat had an epoxy coat barrier...has the boat osmosis?, or absorbed water on the hull?
An old boat can be as new but that means that only the hull and the interior are the same. Almost all systems and other parts should have been replaced. Many that have old boats (or new for that matter) sail only occasionally and use the boat very little and just don't do an adequate maintenance other than visual.
Bottom point you need to know how much money you are going to need to put both boats to specs and probably you are going to need a lot more to do that in a 30 year old boat than in a 10 year old boat (that's why old boats cost less) but each case is a case
