Old 05-13-2011
headcaseracer headcaseracer is offline
Sailing fool!!!
headcaseracer is on a distinguished road
Send a message via AIM to headcaseracer
There are a couple ways to do this. The first and best way would be to remove the mast and the deck plate. Let it dry out and see how much permanent damage you have. If there is no damage, you need to at minimum replace the wooden posts under the mast. If there is damage to to the deck, there are two ways to fix it. The first and hardest is to cut that area out and reglass a new area in. The second way is to have a custom deck plate made that is at least twice as big to help support the weight on the deck.
Headcaseracer
1979 Seidelmann 299
Cruising-Lake Michigan
