SailNet Community - View Single Post - Moisture delam at through hulls
post #4 of Old 05-14-2011
FloridaWriter's Avatar
Originally Posted by jb1528 View Post
I just had a survey done on a Bristol 32. There is moisture around the cluster of through hulls related to the head. Has anyone had this issue? This boat never had a holding tank installed and instead uses a portable toilet so two of the three penetrations are not used.
I'm trying to learn what the repair cost for this might be before I respond to the seller. I'm of course checking with local yards today to get estimates. Has anyone had to deal with this and if so what did you do and what did that cost?
I doubt these were ever rebedded in all these years.
That may be why the PO used a portable toilet. I would guess the area was damaged at some point and poorly repaired. Since the chainplates attach in this same area how far up does the delamination go?
Restoring a 1971 bristol 29
FloridaWriter is offline
