SailNet Community - View Single Post - bilge pump blowing fuses
post #18 of Old 05-16-2011
smeyers18
Gunk in the bilge
I had the same issue with my bilge pump just now and it turned out, as far as I know, to be a little hard chunk left over from last years projects that was sitting directly under the impeller in the base of the bilge pump. I'm assuming it fell out when I removed the top of the pump to see what was going on. Lesson I learned is to look for the physical culprit first before going after a potential electrical issue.
Scott
Currently cruising down the Leeward Islands. Check us out at... Windtraveler or on Facebook at... Windtraveler | Facebook
smeyers18 is offline
