SailNet Community - View Single Post - Midship Swim / Boarding Ladder
post #8 of Old 08-03-2006
sailingdog
It would probably be very easy to modify the ladder to mount to a genoa track car.
What I would do is get two padeye-type genoa cars and then cut a slot into the bottom of the tubing on the top of the swim ladder to fit over the padeyes.
Then drill a 1/4" hole through the tubing that passes through the center of the padeye.
If you insert a 1/4" fast pin, it wil hold the ladder in place.
This makes the ladder easy to move around the boat, and allows you to securely mount the ladder, while allowing you to easily remove the ladder without any tools.
I use a similar setup on one of the mast rests for my boat.
sailingdog is offline
